[WV] ISO: MAP Sensor bracket and Cable routing clip
Old Jan 19, 2015 | 01:33 AM
TPI_GUY89's Avatar
Want a title? Post!
Car: 87 v10 4x4
Engine: 305 currently
Axle/Gears: 4.56
Hello,
Like the title states I am in need of a Map sensor bracket and cable routing clip for my tpi conversion project.
The is the clip I am talking about. (Not sure if routing clip is the technical name.lol)
I have the bolt just not the cable clip
The map sensor bracket I am not sure if they varied by year or not. My tpi unit is an 86 year. I am in search of only the bracket. No need for the sensor.
Please let me know shipped prices to 26866.
Old Jan 19, 2015 | 03:49 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ISO: MAP Sensor bracket and Cable routing clip
That is actually a "spark plug wire" retainer . The OE number is/was 8917256, 85-89 tpi is maf not map.
http://paceperformance.com/i-6305128...clip-spar.html
Old Jan 19, 2015 | 04:39 AM
TPI_GUY89's Avatar
Want a title? Post!
Car: 87 v10 4x4
Axle/Gears: 4.56
I am using as a Map setup. Truck is already speed density so no reason to swap over. Thank you for the link. I assumed it was for throttle cable/cruise routing as I see so many pictures with them run like that.
Old Jan 19, 2015 | 09:05 AM
Engine: Lb9
Transmission: M20
90-92 the map sensor mounts on the plenum. There is not a boss for the map bracket on the maf plenums. You can mount the map to the bulkhead or if you use the divorced hei coil fab a bracket to hole the map between the lower coil bracket and coil. make sure to keep the map a foot or less from its vacuum source.
Old Jan 19, 2015 | 09:49 AM
TPI_GUY89's Avatar
Want a title? Post!
Car: 87 v10 4x4
Axle/Gears: 4.56
Sounds like a plan. My tbi truck already has the divorced coil and the Map bracket located on an intake bolt. I may end up just having to use this route if I cannot add the correct bracket and drill/tap something.
It really irks me to not have a clean supposed to be there look in anything I build. lol
Old Jan 19, 2015 | 09:51 AM
Engine: Lb9
Transmission: M20
another option is to attach it to the plenum extension on the rh side.
Old Jan 21, 2015 | 11:36 PM
TPI_GUY89's Avatar
Want a title? Post!
Car: 87 v10 4x4
Axle/Gears: 4.56
Bump. Still looking for bracket.
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
TheTraut88
Sep 7, 2015 05:22 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
