Swapped the rear end, speedometer is off, help
Old Jan 29, 2015 | 10:28 AM
vargasjc's Avatar
Swapped my stock 87 trans am rear end (2.73) to a Camaro SS 3.42 rear end, love the results. transmission is the700R4. My speedometer is obviously off now, about 15/20 miles/hour higher than normal.
This car has an electric speed sensor in the car, any idea on where I can get the correct speed sensor to fix this issue?
Thanks!
Tires are stock.
Old Jan 29, 2015 | 10:53 AM
couchmotors's Avatar
Car: 1991 camaro rs
Engine: 496 big block
Transmission: th400
Axle/Gears: stock rearend. 3.23
Re: Swapped the rear end, speedometer is off, help
do you have a cable or VSS speedo?
Old Jan 29, 2015 | 11:03 AM
vargasjc's Avatar
Speed sensor looks like the attachment
Attached Thumbnails Swapped the rear end, speedometer is off, help-s8051.jpg
Old Jan 29, 2015 | 11:08 AM
Car: 1991 camaro rs
Transmission: th400
https://www.thirdgen.org/forums/trans...eedometer.html (Sticky: figuring speedometer)
Old Jan 29, 2015 | 11:11 AM
Car: 1991 camaro rs
Transmission: th400
that's fine you have VSS or vehicle speed sensor. but there is still a gear inside that spins that and that's the gear you change to correct the speedo hope this helps
Old Jan 29, 2015 | 11:21 AM
vargasjc's Avatar
Thanks, that really does help!
Old Feb 2, 2015 | 12:12 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You are going to need to change all 3 pieces,....
Your originally 2.73 geared car 'should' have a 17 tooth RED DRIVE gear and a 39 tooth DRIVEN gear...... and a VSS that's good for 39 tooth and lower gears.
You will need:
a 15 tooth GREY DRIVE Gear ( cable and electric use the same DRIVE gear )
A Electric VSS 41 tooth DRIVEN Gear
A 40-45 tooth Electric VSS
Here's a picture of the VSS and the tooth range that will fit properly on this sending unit:
I've got the correct eleceric VSS and the proper Yellow 41 tooth Driven gear you need; $90 shipped. ( Sorry - I don't have the Grey gear, but at least that one is pretty easy to find. ) Send me a PM for more info if your seriously interested.
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
