[CT] Wtb 10 bolt pbr backing plates
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Like the title states I'm looking for a left and right side backing plate set for a 10 bolt rear with pbr brakes. Let me know.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Wtb 10 bolt pbr backing plates
I don't know if they will work for the Dana,....... But I've got a set of backing plates from a 95Z with PBR. LMK if they will work for you.
Engine: 355 TPI
I'm not sure maybe someone can chim in here. I was under the impression I needed third gen pbr backing plates for a ten bolt but I know the fourth gem 10 bolt wasn't all that different
3rd gens used stamped steel for their brakes, 4th gens cast iron. Same dims, same calipers, same everything that matters
If the axle flange and offset are the same as a 10 bolt, theres no reason they shouldnt work on the dana
Engine: 355 TPI
Eh I bought backing plates from bigbrakeupgrade and slammed it all together. I needed to shim between the caliper bracket and backing plate to like them up but that was no big deal. It's all taken care of now.
1badmaro
Apr 16, 2016 08:01 PM
