[MA] Crossfireinjection 2 inch bored set of tbis
Old 09-03-2016, 10:45 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
I need a set of Crossfireinjection 2 inch bored throttle bodies.
Old 09-03-2016, 11:55 AM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
Re: Crossfireinjection 2 inch bored set of tbis
I have a set off a 83 TA Daytona
What do you feel is fair for them
Old 09-03-2016, 08:16 PM
KITT1983's Avatar
are these 2 inch moded ?
Old 09-06-2016, 11:15 PM
bluevette's Avatar
1.920's can be had that retain the balance ports... not all that different than 2"? RV MORSE MACHINE does them if you send a set... I have them and a 2.03" that does not have the balance ports and did not see all that much difference on a 383 stroker both hit 100map... what I can tell you that helped on them is the raising of the injector towers... and shave the bodies to allow the fuel lines to be taken off and on when raised... 3 gasket height worked well, but I made alum spacers and used one gasket and sealer on the tower side... made for better throttle response on a full pedal stomp... or slight press it was more responsive when the cone hit the wall... note different injectors sizes seem to spray differently, I ended up with 90's (86.5's @ 13.5psi) much better cone pattern with the 23psi I am running.
Old 09-07-2016, 05:18 AM
KITT1983's Avatar
im interested send me a pm
Old 04-19-2018, 10:12 PM
KITT1983's Avatar
bump
Old 04-26-2018, 06:02 PM
bluevette's Avatar
rvmorsemachine.com
ray jr
Wheels and Tires
10-14-2016 08:40 AM
Rls4762
09-02-2016 12:36 AM
turboguard
Carburetors
08-31-2016 07:40 AM
QUICKCHICKEN
08-21-2016 11:49 PM
AW119 Pilot
Wheels and Tires
08-21-2016 04:43 PM
Quick Reply: [MA] Crossfireinjection 2 inch bored set of tbis
