2006 18 inch GTO wheels on 3rd Gen Camaro?
Car: 1991 Camaro RS and 1992 Camaro RS
Engine: 305 soon to be a 383 or 427 SBC
Transmission: T5 and 700R4 soon to be ?
Axle/Gears: Stock...
I am wondering if anyone has tried these wheels on their Camaro? The bolt pattern is correct 5x4.75 and they are eight inches wide. Not sure on the back spacing? Any information would be appreciated. Thanks in advance. Mike
Re: 2006 18 inch GTO wheels on 3rd Gen Camaro?
They do not fit...
Car: 85 Firebird C&C T-Top
Engine: 347ci LS1
Transmission: 4L60E LS1
Axle/Gears: BW 9 Bolt Posi,3.27,C5+VE Brakes
No they will not fit.
As far as i can tell its the same as the Australian counterpart that its based on, which is in fact 5x120mm not 4.75"/120.65mm. The offset is also way off.
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Even if they are 5x120 and not 5x120.65 they will still work with wobble bolts, or if you just don't care run the normal lugs. How do you think people get BMW wheels on our cars?
Engine: 347ci LS1
I won't get into this argument over bolt pattern, a question was asked and i simply provided the facts, they are 5 x 120 not 5 x 120.65, and the offset is way different to 3rd gen offset.
What you do beyond that is at your own risk and/or discretion.
Car: 1984 F41 Camaro
Engine: LC1 V6 2.8L
Transmission: 4 Speed Auto
it is possible with modification is the correct answer, they will not fit without some sort of modification to correct the offset and bolt pattern
Going Slow Sucks
Aftermarket Product Review
Dec 11, 2001 05:15 PM
86TpiTransAm
Mar 4, 2001 12:47 AM
