[FL] Looking for a WP pulley and a PS pulley
I'm looking for a Water Pump Pulley PN#10055880 and a Power steering pump pulley PN#14102096.
There off a 92 Camaro 5.7 Serpentine Belt system.
I have all the other parts but those two pulleys.
Thanks,
Chris,
Thanks,
Chris,
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Looking for a WP pulley and a PS pulley
You might look in the classifieds section the Pulleys were used on 88-92 tbi f body’s too.
The waterpump pulley is still available new. Look around on Rock Auto it should be there.
Look for ACDELCO 19368329
Same with the crank pulley. GM #10055879
https://www.gmpartsdirect.com/oem-pa...ulley-10055879
Probably can find these cheaper if you shop around. There might be alternate part numbers too. All 88-92 V8 thirdgens used the same pulleys. B-body boats like the early-mid 90's Caprice, Roadmaster, Fleetwood, etc with TBI did too. Thanks to GM offering the serpentine setup as a GM Performance Parts item, everything is still offered new.
Almost forgot... Here's a 5% off code for Rock Auto to soften the blow (suck?) of sticker shock.
8113040272877486 Enter the code in the "How did you hear about us" box without any other numbers or characters.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I have a used water pump pulley $40 shipped.
Yea I saw them on rock auto trying to do it on the cheap.
I'm in between jobs right now and I want to Put my 71 Camaro together and I have a ton of stuff to get so I can save some money and refurbish some good stock pulleys.
Thanks for the info I did do some research on it.
I have all the other matching pulleys to a Camaro so I want to get the matching WP and PS pulleys so I have a matching set.
91RSCamaroSteve
LSX and LTX Parts
Feb 2, 2013 05:30 PM
TADailyDriver
Aug 19, 2009 01:58 PM
YenkoST
24
May 12, 2009 09:40 AM
TRXSandRacer02
Sep 10, 2006 09:20 PM
warrior_91
Nov 5, 2003 12:48 PM
