[UT] Need set of flexible fuel hose w/stock connectors
Old Jun 11, 2018 | 08:26 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Engine: 90-95 ZZ4 Crate 350 TPI
Transmission: 700R4 4spd Automatic
Axle/Gears: 3:73
Good evening,
As if anything else could go wrong during this 305-350 TPI swap, I was getting ready to fire her up and check my distributor timing when out of the corner of my eye I see a 3" pinpoint stream of fuel coming out of one of my flex hoses that supply both primary and return fuel to my injector rail.
I have searched the web and came up with nothing, called all the standard parts stores and still nothing.
If anyone has a set of these that are in really good shape and wants to part with them or: If they have converted the stock to custom braided, I would love to know the specs and coupling requirements so I can build a set for my ride.
I'm absolutely dead in the water until I get these lines replaced.
Text me at 385-888-4619 if you can help
Steve
Old Jun 11, 2018 | 10:02 PM
Drew's Avatar
Re: Need set of flexible fuel hose w/stock connectors
Could always CAREFULLY cut through the crimp sleeve around the hose, peel the old hose off the fittings. Then hit your local hydraulic supply shop, and have them assemble your original fittings into new hose with new crimp sleeves.
Consider how old a used hose is, what it'll cost, and the shipping... Vs buying a new length of hose, and paying for a smidge of labor...
Old Jun 12, 2018 | 07:58 AM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
If they are the same as the 305 lines, I have a set of them.
Old Jun 12, 2018 | 06:47 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Okay Drew. I will work on that. Get hem off and see If I can find someone to reproduce them. You may be right about used ones. May be jumping into a another failed set. Beths91Camaro, If I get backed into a corner I may entertain that set. Both the 350 and the 305 fuel rails are identical, except for how the lines feed through the serpentine belt brackets. I have a 350 in it now, but chose to stay with singular belt drive system to maintain the 1986 appearance except for the tell-tale center bolt valve cover configuration, it looks like a 305...
Old Jun 12, 2018 | 09:25 PM
Here they are, if you find you need them.
Attached Thumbnails Need set of flexible fuel hose w/stock connectors-dsc08008.jpg   Need set of flexible fuel hose w/stock connectors-dsc08009.jpg   Need set of flexible fuel hose w/stock connectors-dsc08010.jpg   Need set of flexible fuel hose w/stock connectors-dsc08011.jpg
Old Jun 17, 2018 | 10:19 AM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
ok, let me see what house of houses comes up with. The hoses have been at the shop since last Thursday. I will definitely contact you. What kind of price are you looking at?
Old Jun 18, 2018 | 10:35 AM
$30 shipped
BWilcox
Jun 19, 2018 06:47 PM
Pablo
33
Dec 31, 2005 09:13 PM
