can i change my steel fuel lines to flexible ones (the ones near the intake)??
Old Feb 28, 2001 | 02:33 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
the fuel lines that o from teh flexible parts near the power steering pump to the throttle body...can i switch them to flexible lines?
what are my opttions?? the steel lijnes are a huge pain in the a$$, so i want to try to get rid of them if possible.
thanks
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Intake, Holley 670 CFM TB, Edelbrock Water Pump, March Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Rapidfires, Hypertech Fan Switch & Chip, SLP 1 3/4" Stainless Headers, 3" Cat Back, Flowmaster 40 Series
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Feb 28, 2001 | 04:59 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
go to local speed shop, they should have what you need, i dont see why not, maybe cover em with heat sheild of some sort, i plan on doing this soon too.
Old Feb 28, 2001 | 05:00 PM
Andys92RS's Avatar
There really no reason why you couldn't use flexible line. But, I would look into using Aerquip lines and fitting. It would give you added insurance agaist leaking hoses and clamps. Besides it looks alot better. I've checked out your car, it deserves it! I'm not sure what size the fittings are though. I'm going to have to do the sam thing, keep me informed.
Were in NY are you. I'm from Binghamton. I live in VA Beach right now, but will be moving home in June. I'd like to hook up with the Camaro clubs in NY when I get there.
Old Feb 28, 2001 | 05:13 PM
scauffiel's Avatar
I'm looking into this right now. Apparently full size TBI trucks from '87-'90 got stainless flex fuel lines that are a direct bolt in for ours. I'm going to try to run mine from the hard lines back along the firewall to the TBI. I had a whole bunch of text that someone from the DIY-Junkyard turbo list had done that showed all kinds of things that swapped out between our cars and that was one of them. If I find the pages I'll post a copy of it here. If you find out if this works before me, please post it here as well!
Steve
Steve's Trans Am Temple
Old Feb 28, 2001 | 09:42 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Andy92RS...you have mail...
-brian
Old Mar 2, 2001 | 10:17 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
well i got the parts today to do it, and it can be done...actually it was pretty easy, so i guess it was stupid to ask in the first place...oh well..ill post some pics when i get it done.
-brian
Old Mar 2, 2001 | 06:18 PM
snflupigus's Avatar
how much. Got pics?
what lengths etc..?
info info info info
thanks.
Tech article ??? Would be great for everybody if you just wrote up something short.
Old Mar 3, 2001 | 12:53 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
ohh goood idea...maybe i will..i only spent like less than 20 bucks, but the problem is that i couldnt find the right fittings to replace the 12" or so of the rubber lines near the power steering pump. so, they are still there, for now.
also i rerouted them around the back of the engine i think. i still odnt have them permanently in, but it looks like they are gonna stay there. ill let you know.
-brian
Old Mar 3, 2001 | 09:51 PM
steve8586iroc's Avatar
I saw the hoses and fittings in my jegs catalog last night. If I just knew witch size fittings I needed I would order mine this week, but I'm just not that familure with threadnology to figure it out. I guess I'll have to ask someone with nollllodge to find out.
I think this would look cool with the new rpm air gap I'm putting in.
Steve
Old Mar 6, 2001 | 05:24 PM
Andys92RS's Avatar
Brian, I don't know if this will help you any or not but. I found this fuel line extension for Throttle bodies for use with spacers. It might not work a flat Holley adapter plate, being thats it's just an extension on the back of T-B. I still think a custom set up using aeroquip lines and fittings would be better. just a thought.
-Andy
www.tdperformance.com/ppdir_28.html
Old Mar 6, 2001 | 05:39 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Andy..
yeah that may have helped my original problem a little, but not really. they were pretty much "all over the palce" and had to be replaced one way or another.
thanks anyways though.
-brian
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
MENINBLK
Aug 5, 2015 11:58 PM
