[FL] 1982 V6 Automatic
Old Dec 24, 2018 | 07:37 PM
Oldpackrat's Avatar
1982 V6 Automatic
Help!!!! Need a "pigtail"!, Mouse cut wires! Unfortunately I can only describe what I need. On driver's side of firewall there is a small box with 3 wires plugged into the bottom. The plug is grey, has a lime green "gasket" surrounding the three small "pipes" on the upper side of the small connector plug. There are 3 wires coming out of the connector plug, one is green, one is grey or purple, the third wire is black. The little box the wires plug into is attached to the firewall and located just above the point where the driver side wheel well meets the firewall. If you have a 2.8 1982 V6, you may have what I am looking for. Mine is an automatic, but maybe all '82 V6s had what I need, wish I had an 82 wiring diagram! Thanks!
Matt Bane
Dec 19, 2009 10:11 AM
the_am_man
Jun 19, 2006 01:31 PM
blyth18md
Sep 30, 2003 10:07 PM
morale
Jul 15, 2003 03:46 PM
