Engine wire harness an computer for tpi 1988
Old Nov 10, 2019 | 05:55 PM
det88vert's Avatar
My guys i got z 1988 vert. Wire harness was cut up pretty bad. Belive the person who owned car before me was running a carb. I believe the computer in there is for a 305 tpi. Im not sure if i can use it for my 350 tpi swap or should i get a 350 ecm.. Im looking to purchase a wire harness that will fit and work for a 88 iorcz. Thanks alot. I have purchased numerous parts from this site so let me know... I'll go to the wrecking yard probably tomorrow to see if i find something good but until than let me know..!!!
Thanks guys
Old Nov 10, 2019 | 06:00 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Engine wire harness an computer for tpi 1988
The harness you can use from a 88 or 89. The only difference is the 89 will not have the cold start injector.
if you post the letters off your computer chip I can identify it.
For a harness you can adapt one from speedway motors.
https://www.speedwaymotors.com/speed...ess,46372.html
Old Nov 20, 2019 | 09:28 AM
TimothyPaul's Avatar
I have a complete 88 engine harness for sale if you are interested...
https://www.ebay.com/itm/25423687966...84.m1555.l2649
Old Dec 20, 2019 | 01:25 AM
ambainb's Avatar
Car: 86 iroc
Engine: Iron 408 LS3 combo
Transmission: Ram10 T56
Axle/Gears: 3.73 10 bolt :)
I have a complete tuned port injection system top to bottom ECU harness right down to the spark plug wires even have the firewall brackets and relays 100% complete $250 shipped
Old Dec 20, 2019 | 09:34 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
I also have one. 89. No csi. Complete with 350 tpi ecm and og prom. 170 shipped.
Wigginsja
Oct 19, 2019 10:53 AM
Bobby Suth
Apr 29, 2018 08:48 PM
JOHNCOO5
Oct 30, 2004 01:51 PM
