WTB ECM chips for 85 350 swap
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
I have 85z28. I am putting in a 350 block and plan to keep TPI. I need the correct chips/memcal. Can anyone help? I do PayPal. Thanks
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Re: WTB ECM chips for 85 350 swap
If you are looking for off the shelf chips you will need them for a Corvette I believe. Or have one custom programmed from a capable member here
Thanks for the response, have a great day
I'm not sure if that is the number, at work tied up right, I will check later thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If that’s the ecm you have I have a 85 corvette prom.
tpi 350 cast iron heads 22#hr injectors Automatic transmission.
Yes that's the right number, how much for the chips? Thanks
Sounds good, will need your your PayPal address, u can send me a PM, I'll add 3% fee thanks
85 ZXX
Mar 14, 2010 05:51 AM
R3500
Jun 8, 2008 10:34 PM
