[NJ] WTB complete stock tpi intake setup
Old Oct 12, 2020 | 09:48 PM
msammy93's Avatar
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
want to go back to the stock tpi setup so need intake, plenums, throttle body, and fuel rails.
Old Oct 13, 2020 | 09:21 AM
firebirddude142's Avatar
Car: 1992 Trans Am GTA
Engine: L98 5.7L 350
Re: WTB complete stock tpi intake setup
For what year? I have one off a 92 pm or text me my number is (612) 860-2513
Old Oct 13, 2020 | 09:46 AM
my82roc's Avatar
Car: 89 Iroc Convertible
I have a tpi setup from an 85-88 located not too far from you in Levittown bucks county pa
Old Oct 13, 2020 | 01:58 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Just got done blasting a set-up last week....... Will post some pics ASAP.
Old Oct 14, 2020 | 11:07 AM
John in RI's Avatar
Here's a pic:
Throttle Body, Thermostat Housing, EGR, Throttle Bracket, and Fuel Rail were coated in primer/sealer. Ther'es no TPS sensor on the TB and it's missing a couple screws on the coolant plate ( holes are GOOD). Cold Start Switch is not included. I've got 2 pairs of runners; 1 pair has a couple little dents & the other set has just a couple minor dings; both are for cold start injector. Intake is from an 87 or 88; PN 10088015.
Old Oct 20, 2020 | 11:32 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
If you haven't already bought a TPI setup I am local to you with a complete setup. Could come pick it up from a 91 Formula
