LT! cam
Old Jan 25, 2021 | 04:56 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
LT! cam
Looking for a good deal on an LT1 cam for my 350 stealth ram build
Old Jan 25, 2021 | 05:57 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: LT! cam
there isn’t anything special about an LT1 cam.
just buy the cam that best fits your engine combo and intended usage.
HSR is a mid to high end intake. So you are best with a cam that lives well in the 2000-6000rpm range.
depending on your combo something that peaks around 5000-5500 is probably best for a street car power band.
intake duration should probably be kept in the 215-225* @.050 lift on a 112-116* lsa.
so many variables to work though.
Old Jan 25, 2021 | 06:16 PM
Re: LT! cam
Basically. Before ANYONE can recommend a cam, we need to know in exact detail exactly what parts you have, intend on purchasing, how much money you are willing to spend, and what you REALLY want out of the car.
I have a built LT1 with a fairly aggressive cam, but not the MOST aggressive cam you can run on the street. Its a rocket ship when you are flat to the floor, but absolutely terrible at anything less than 2500rpm. Gutless is the word I'd use. If someone told me I had to keep it under 3000rpm, I'd lose to a 305 TBI car in a drag race.
Old Jan 26, 2021 | 03:37 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
Re: LT! cam
My Friend has one listed on FB Marketplace
https://www.facebook.com/marketplace...3216326744543/
Old Jan 27, 2021 | 07:36 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: LT! cam
I like the #049 GM L98 cam better. More duration 207-213.. Less lift at 415-431 but id take it over the LT1 cam.
Old Jul 11, 2021 | 07:44 AM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
Re: LT! cam
Are you still looking for a cam? I'm selling a GM485.
xxbrew1690xx
May 25, 2012 08:12 AM
lokoRS
Apr 27, 2004 01:58 PM
Ace
Nov 22, 2003 03:30 AM
CRZYTRN-92Z28
Sep 3, 2003 08:11 PM
