The shorter plenum bolts 89 tpi- need 1
Car: 89 formula 350
Engine: 5.7
Dropped it and disappeared. Last one on drivers side. Looking for where to get one. Also broke a screw for the distributor cap cover. Would like close to oem look. Please and thanks.
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
Re: The shorter plenum bolts 89 tpi- need 1
they are M8x1.25, the shortest ones are 30mm, the longer ones are 40mm and 45mm IIRC
EDIT: it looks like McMaster-Carr has exact ones, but at the time I wanted to get some on that same day in person.
https://www.mcmaster.com/torx-screws...d-torx-screws/
vincode8
Apr 8, 2007 01:21 AM
