TPI cover bolts
Old Apr 23, 2006 | 04:25 PM
Formulabruce's Avatar
TPI cover bolts
I need the cover bolts for the rear dist cover on my tpi I would like original bolts which seem to be missing on every parts car I see, if not, what size are they??, are they metric?? (the 3 scre holes at rear of tpi)
Thanks!~
Old Apr 23, 2006 | 08:23 PM
Damon's Avatar
Don't know for sure but I bet you're right about them being metric.
Old Apr 23, 2006 | 08:27 PM
fireball451's Avatar
Car: 91 Z28, 91 Z28, 92 Z28
Engine: LB9, LB9, L98
Transmission: T5, T5, 700r4
Axle/Gears: 3:42, 3:42, 3:23
Did you try:
MODERN DAY MUSCLE - HOME
(formerly perrypam.com)?
They got alot of used hardware, torx screws etc.
Guess if you use anything other than the torx screws, it won't look right.
Old Apr 23, 2006 | 09:00 PM
I-rocin's Avatar
Car: 87 iroc-z28
Engine: vortec tpi 350
Transmission: built 700r4
tpiparts.net sells the original ones, gm product
it'll cost you 12 dollars
Old Apr 24, 2006 | 03:09 PM
GREAT THANKS!!
Old Apr 24, 2006 | 04:09 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
For reference; GM part # and GMPartsDirect.com price below:
14082425 TPI Distributor Cover Bolt 2.52 each
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
