[MI] Stock 88 305 TPI Throttle Body
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Hello,
I bought the car and the PO had put on a 58mm BBK throttle body.
To eliminate any potential issues with this unit, I would like a stock one to play with.
Does anyone out there have one for a reasonable price?
Thanks!
Thanks!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Stock 88 305 TPI Throttle Body
I have several 85-88 48mm stock tb.send me a pm with your email address if you want me to go snap pictures.
Engine: Lb9
Transmission: M20
All have about the same shaft play, last without air coil coolant plate cut. Air foil one $85 shipped
others $70 shipped. Two have different bolts for tps stock is the ford head one.
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
im in michigan with a stock one or two laying around. id trade you the bbk for it?
