52mm throttle body on a stock TPI?
Axle/Gears: GM 9-Bolt
Hey guys I'm wondering if a 52mm throttle body would work on a stock 350 TPI and not cause it to run funny
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 52mm throttle body on a stock TPI?
Yes it will work fine, but no its not needed on a stock engine.
Car: 1997 z28
Engine: lt1
Transmission: t56
cant recommend it. i ran a 58mm throttle body on my stock 305, it ended up blowing my engine. it really wont give you any gains and there are alot better things you can blow 300 bux on. upgrade your suspension instead, stock engine is quick enough unless you got a whole lot of money
Car: 1991 Trans-Am "Blackbird"
Engine: 305TPI LB9
Axle/Gears: Hmm
the larger throttle body won't exactly make your car faster or more powerful... let me try to find a way to explain it.
a larger throttle body will only make wide-open-throttle come quicker. there's less of an "in between". people say they gain huge increases in the car's response, but i'll put it this way-
pretend a throttle body is a ruler... you have two rulers, one stock and one "upgraded" ruler. it takes you 5 seconds to move your finger 5 inches up the STOCK ruler. on the upgraded ruler, it take's you 3 seconds to get to 5 inches. --> you're still going up only 5 inches, but it's now taking you less time. you gain no height in the "upgraded" ruler.
get it?
i just read that all over again... jesus man
get it?
i just read that all over again... jesus man Joined: Jul 1999
How does a throttle body blow up your engine? I find that hard to believe without more information.
Engine: 305TPI LB9
Axle/Gears: Hmm
I don't think the throttle body blew his engine, I bet because it's easier to reach a higher RPM, it may have over-revved or it just wore out quicker. Maybe?
so basically all it does is increase throttle response by a little
Engine: 305TPI LB9
Axle/Gears: Hmm
Yeah, but I can't say it wont make your car quicker though or give you more horsepower (I don't have figures to stand behind as proof).
Car: 1997 z28
Engine: lt1
Transmission: t56
maybe that was a bad word choice. my engine didnt actually 'blow up' or anything, what did happen was the mass air flow sensor went bad the day after i installed the throttle and i can only assume it is to blame. thats an awful big coincidence, and it was a 300 repair that i really didnt want to do plus i put the old throttle back on. so, when i say blew i meant more like ruined, all though its fine now. sorry for the confusion
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by solaris_vii
maybe that was a bad word choice. my engine didnt actually 'blow up' or anything, what did happen was the mass air flow sensor went bad the day after i installed the throttle and i can only assume it is to blame. thats an awful big coincidence...
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
I just read most of the post and a bigger TB will hurt throttle response, the air volume will increase but the velocity will decrease.
The only gain would be in WOT but unless supporting mods are done you will see probably no gain ( more likely to have a placebo effect ). Think of it like this....
Turn your garden hose on water flows but not much pressure (thats the 58mm TB). Now take the hose and put your finger over it, the pressure increases and the water come out faster but theres slightly less flow. ( factory TB)
Car: 1997 z28
Engine: lt1
Transmission: t56
It's not as big of a coincidence as you might think. The throttle body is obviously after the MAF sensor (in terms of incoming air), which would immediately point to possible damage of the MAF sensor (in your case) during the throttle body's installation (MAF's are very sensitive). Even with a bigger throttle body, the intake's plenum, runners, base, as well as the cylinder head ports, are exactly the same. So the concept of such a drastic increase in air, causing any serious damage, is totally unrealistic. Without the supporting mods, a larger throttle body is simply a waste of money. No real harm though....
A turbocharger and a supercharger are two different things. What you are describing is a supercharger. See the power adder forum for more info on those.
Originally Posted by Saigon_Bob
I just read most of the post and a bigger TB will hurt throttle response, the air volume will increase but the velocity will decrease. The only gain would be in WOT but unless supporting mods are done you will see probably no gain ( more likely to have a placebo effect)....
Think of it like this. Turn your garden hose on water flows but not much pressure (thats the 58mm TB). Now take the hose and put your finger over it, the pressure increases and the water come out faster but theres slightly less flow (factory TB)....
But this is being based from the other end of the spectrum though. I could see how this analogy would relate to engine exhaust backpressure, but I can't see how it would relate to incoming air though....
....but more to the point of this thread, on this 305 naturally aspirated engine, the heads, exhaust, TPI, cam etc. etc. etc. all dictate airflow, so unless the throttle body is choking the "system" (which the stock 48mTB is not) it doesn't make a difference.
....now add a supercharger or turbocharger, and that all changes. The pressure is now coming from the other side of the equation. Regardless of how much air the engine can handle, if it the blower/turbo can't push it past the TB, it isn't gonna make more power.
....but to bottom line it for the point of this thread, a 52mm should run just fine, and may add a smidge of snot to the motor, it may cost you a snoodge, but ultimately you won't feel it either way.
Originally Posted by Abubaca
OK, removing THE ENTIRE TPI from mix, and only talking about the throttle body, a bigger throttle body (no finger on hose) will slow down air at lower rpms, but ultimately flow more air.
If it's a MAF oriented system, the ECM is told before the air even reaches the throttle body exactly how much air has entered the intake. Whether the throttle body is 48mm, or 58mm, the air was already calculated before hand, and provided the plenum's orifice doesn't cause any turbulence (with a larger throttle body), there won't be any problem whatsoever. Speed Density obviously basis it's calculation a different way, but regardless, as already pointed out, the stock 48mm throttle body can already flow more air than it actually does, but the engine isn't demanding it due to the rest of the TPI's system....
Carburetor's, however, are an entirely different story....
so what basically if you do anything with a throttle body replace the MAF cuz its junk or replace it and get a better flowing MAF
Originally Posted by DirtyracingGTA
so what basically if you do anything with a throttle body replace the MAF cuz its junk or replace it and get a better flowing MAF...
Here ( Click Here), not bad for a stock MAF, eh....?
Street Lethal: I think we're saying the same thing.
Gotta love unspoken communication!!!
DirtyRacing: Regardless what engine you have, it's ultimately one big air pump. At some point, some part is flowing at it's max, and no matter what other parts you have, the engine stops making power. Kinda like a professional marathon runner breathing through a straw. No matter how much conditioning you have, you simply can't get enough air through a straw for a runner to breathe. So one by one we replace the restrictions. Heads flow more air, cams open valves farther, and keep them open longer, exhaust gets rid of MORE exhaust gas, bigger injectors gives MORE fuel to burn with MORE air. IT's all about getting air in, burning it with fuel, and getting it out.
So where' the restriction on a stock 305? A LOT of it is exhaust. That's almost always a FIRST mod to any factory engine. Under the hood, probably the heads or the intake manifold itself. Unfortunately, it's not as simple as a runner breathing through a straw, and there are a LOT of factors to consider. But the stock air intake box flowing through a stock MAF sensor, flowing through a stock 48mm throttlebody will provide enough air for a pretty stout 350. ....it's quite awhile before a 305 needs to upgrade those parts.
Gotta love unspoken communication!!!DirtyRacing: Regardless what engine you have, it's ultimately one big air pump. At some point, some part is flowing at it's max, and no matter what other parts you have, the engine stops making power. Kinda like a professional marathon runner breathing through a straw. No matter how much conditioning you have, you simply can't get enough air through a straw for a runner to breathe. So one by one we replace the restrictions. Heads flow more air, cams open valves farther, and keep them open longer, exhaust gets rid of MORE exhaust gas, bigger injectors gives MORE fuel to burn with MORE air. IT's all about getting air in, burning it with fuel, and getting it out.
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
lol, this is a good thread.
Car: 1991 Camaro RS
Engine: 357cid
wow this was a great discussion... lol well i see the points of everyone. and i think the general concensus is that you could spend $300 in a better place.
I personally do not care for larger throttle bodies on street cars. In most applications (especially mildy modded street cars) they're a complete waste of money. I can tell you for a fact, that installing a larger throttle body on your car will give you NO power increase what so ever. Zip. Zero. Nada. Nothing.
What it will do, is destroy your throttle response and may even give you a "stumble" or "bog" off the line. That is what happened with my LT1 Formula ( http://www.cardomain.com/id/lt1fun )
after installing an Edelbrock/BBK 52mm throttle body and it took me forever to finally figure out what the problem was. It was such a frustrating time trying to figure out why my car developed this stumble, out of the blue.
I kept getting this "bog" off the line, where there was a slight pause between the moment I hit the gas, and the point where the car actually stated to accelerate. The car would always stutter whenever I'd give it 1/4 throttle. At the time, I figured it was ignition related so over the following couple weeks, I eventually ended up replacing ever part of my ignition system which (back then) cost my well over $1000 CAD.
Still didn't solve the problem. It wasn't until I met up with an old friend of mine (who happens to be a mechanic) that I finally figured out the problem. I explained to him the symptoms and he asked me what was the last thing I did to the motor before I started having problems with throttle response. After thinking about it, I finally remembered that the throttle body was the last thing I did to the car and he said "BINGO! That's your problem right there."
He then explained to me about how/why larger throttle bodies often cause drivabilty issues and suggested I remove the 52mm and re-install the stock 48mm. I was hesitant to do so at first, mainly because I had just finished spending $450+ on this new fancy throttle body and it was such a really nice looking piece. But I was desperate to find out what the problem was and willing to try anything. I figured if the 52mm throttle body wasn't the problem, I could always just put it back on.
To make a long story short, immediately after installing the stock T.B. back on the car, all drivability issues disappeared. Throttle response was smooth and crisp. No bog. No stumble. The car was right back to the way it used to be.
I was happy but at the same time pretty pissed. I mean, on the one hand, I finally solved the drivability problems I was experiencing. On the other hand, I came to the sad realization that I had just spend $450 on a part that didn't give me one single horse power and instead ended up costing me over $1000 in ignition "repairs" that were never even needed....
For the record, I did put the car on the dyno after installing the larger throttle body (I always put my car on the dyno after upgrading anything)
and after 4 runs, the car didn't make any more HP than before. This was on a heads/cam LT1 mind you (with a ported intake manifold), and I was putting more than 360+ at the wheels N/A and over 500RWHP on the spray. On both passes on (and off) the nitrous, I gained absolutely NOTHING !!!
Needless to say, i was pretty disappointed with the results and I tried to comfort myself in the fact that even if I didn't gain any HP, at least the new throttle body looked cool and gave the car a "sucking sound" through the intake that made it sound like I had a blower on the car
Looking back now, it was a learning experience for me.
There's was a lot of dumb things I bought for that car that were a complete waste of money. I guess I was just suckered into the magazine ad's and internet talk and just believed a lot of what I read. Now with my IROC, I'm going off of personal experience and only buying parts that I know are actually worth it.
A larger throttle body definitely is NOT one of them.
A stock 48mm TPI TB flows aprox. 780cfm, which is already more than what a stock (or aftermarket) TPI set-up could ever hope to take advantage of. Really, there is virtually no reason to upgrade to a larger throttle body if you're running a TPI intake.
It's your call really but I wouldn't recommend a larger throttle body at all.
I've never seen anybody gain any HP out of a larger throttle body other than those with highly modified motors with power-adders such as a Turbo or a supercharger. A TPI motor will not benefit from a larger TB, I can assure you.
For the money you'd spend on a 52/58mm T.B. you could upgrade to a set of 1.6 roller rockers and pick up a guaranteed 15-20HP.
You could get a custom Chip burned for your car. A set of headers, cat-back etc. etc. etc.
Learn from others mistakes my friend. It'll save you a lot of time/energy/money/grief
Sorry for the long post.
Car: 1991 z28
Engine: unknown at this time
Transmission: auto
hey whats up! i have a 91 z28 tpi i thought i understood that stock tpi throttle body was 52mm and you had to get the plenum bored for the 58mm am i wrong or right??
The 58mm will work on a stocker, but it would probably be beneficial to port the plenum and get some high-flow runners while you're at it.
...52mm is PLENTY for a stock motor. The 58 is better for a cammed, possibly FI application.
Originally Posted by LT1FUN
What it will do, is destroy your throttle response and may even give you a "stumble" or "bog" off the line. That is what happened with my LT1 Formula after installing an Edelbrock/BBK 52mm throttle body and it took me forever to finally figure out what the problem was. It was such a frustrating time trying to figure out why my car developed this stumble, out of the blue....
Also, if the plenum's orifice wasn't ported when the aftermarket throttle body was installed, a whistling noise would most likely be prevalent (turbulence, which sounds a little like a blower), which obstructs airflow, and could of assisted with the slight hesitation you described, although it honestly sounded more like a flawed TPS setting though in your case. The only time I see an immediate problem when installing a larger throttle body, is when you install a bigger carburetor on a stock engine. This is mainly because the ECM can't really compensate for the added air like it can w/fuel injection, as well as the LG4's intake system not being as limited as the TPI's w/air flow...
When installing a larger carburetor, the engine immediately realizes the additional air being presented. When a larger throttle body is installed on a TPI engine, the air isn't immediately realized, because the stock 48mm throttle body still has yet to even be maxed out, due to the stock TPI system's limited air flow potential....
Read this thread again. Stock is 48mm. 52mm and 58mm are aftermarket upgrades. If you put on a 58mm, yes you should get the plenum ported to match the larger throttle body.
Terrell351
Jun 13, 2021 01:13 PM
1985corvette, 1987, 52mm, body, carburetor, change, exhaust, fuelinjection, gta, horsepower, noise, specs, stock, sucking, throttle, tpi, trans
