Looking for a 1988 -1989 Firebird tpi engine harness for a automatic
Old Nov 16, 2021 | 09:00 PM
Rainmaker491's Avatar
Want a title? Post!
Been looking for one and not having any luck
Old Nov 16, 2021 | 10:02 PM
2irocs's Avatar
Car: 1989 Iroc Camaro
Engine: 383 Stroker-Carb Blue Print Engine
Transmission: automatic
Re: Looking for a 1988 -1989 Firebird tpi engine harness for a automatic
HAWKS MOTORSPORTS in South Carolina has a harness for a Fireird $350.00...
Old Nov 16, 2021 | 10:06 PM
2irocs's Avatar
On the right side of this page click on HAWKS THIRD GENERATION
Old Nov 17, 2021 | 06:39 AM
Want a title? Post!
They say have them on their website but when you call the don't have any
Old Nov 17, 2021 | 08:59 AM
2irocs's Avatar
There was someone on here that started a thread posting they had a bunch of camaros they were parting out...that post was in the last month on here...you might want to go back and look at previous post within the last month...if i see the post i will let you ,know...
Old Nov 17, 2021 | 07:09 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
I sold one recently but I think I have another. Ill check
Old Dec 14, 2021 | 01:10 PM
live4formula's Avatar
Car: Bright Red 1989 Firebird Formula
Engine: LB9 5.0L TPI
Transmission: MM5 5 Speed Manual
Axle/Gears: 3.45
I have one out of a 1989 Formula 305 TPI automatic. The pigtail to the dual electric fans has been cut off (sold with the fans, but the rest is in tact with ECM. $250 shipped in USA.
Old Dec 14, 2021 | 03:15 PM
Want a title? Post!
Is their any connectors broking or cut wires
Old Dec 14, 2021 | 03:27 PM
Axle/Gears: 3.45
I can inspect a little closer tonight when I get home, but the only thing I am aware of is the tail to the dual electric fans was cut where it came out of the main harness along the frame rail. It was cut off and sold with the fans.
Old Dec 14, 2021 | 03:35 PM
Want a title? Post!
Ok it's going to be a few days to get the cash
Old Dec 14, 2021 | 05:34 PM
Axle/Gears: 3.45
All wires and end connectors are good except for the fan pigtail (attached picture) and there is a cluster of 5 wires coming out of the harness along the back of the driver side frame rail. I don't see anything on the car that has been cut in that area, so I'm not sure what they go to (see pic). I also attached a pic of the ECU.
Old Dec 14, 2021 | 06:59 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You need to be specific, 1988 or 1989
they do not interchange.
Old Dec 14, 2021 | 07:10 PM
Axle/Gears: 3.45
The harness I have available is from a 1989 Formula with 305 TPI automatic
Old Dec 19, 2021 | 08:51 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
The 88 from some of the GTA 5.7 cars had vats and the 89 model year all had vats. So if you want a non vats harness you almost have to get a 5.0 or non vatts 5.7 Camaro or formula. Or change out the dash harness and steering column
Old Jan 19, 2022 | 09:28 AM
Want a title? Post!
Do you still have the 1989 tpi harness
Old Jan 19, 2022 | 12:30 PM
Axle/Gears: 3.45
No. the harness has been sold
816ledge
Mar 24, 2021 05:27 PM
89irocz355
20
Aug 14, 2013 07:08 PM
duece
Dec 4, 2011 12:47 PM
