Have a brand new erson bought as part of a package and never used, was mocked up and pulled engine never fired in box with cam card and cam doctor report. I realize the specs are more aggressive than what you want, but figure I'd offer it up. I'll take 85% of current retail shipped. Figured I'd save it for a 355 blow through setup I had in mind. Was purchased late 2019. Have the report card too, but no pics on my phone of it.
It is stepped nose for lt1/L98 I had to knock the pin in a little to make flush with cam sprocket on the l98, so you could use a slide hammer and pull it out to work with the opti on the lt1 if need be. Definitely not a retrofit cam.
as you can see the engine never ran with the cam installed. Bought with heads, intake for the l98, ended up buying a 383 short block and got a better matched cam for it's compression and this went back in the box.
