Wanted - 83-86 Camaro L69 305G Dual Snorkel Air Cleaner Top Wing Nut & Stud
Hi:
Looking for an Original GM 83-86 Chevy Camaro L69 305G Dual Snorkel Air Cleaner Top Wing Nut & Carburetor Stud. My Camaro GM Book does not list a Part Number for the Wing Nut, all its lists is the following:
Nut - Wing (M6x1)
Carburetor Stud GM Part #: 14048874. Same Stud on the LG4 305H
See Original Camaro L69 Photo of the Top Air Cleaner Wing Nut and Stud
Re: Wanted - 83-86 Camaro L69 305G Dual Snorkel Air Cleaner Top Wing Nut & Stud
I believe the wingnut is the same as G-Body 305. Interestingly, my GM parts book for 82-90 B, G, T, X, doesn't list a V8 wingnut for H, G, N engines, either. The wingnut probably was a bulk item, in packs, and didn't need listed how we usually see called out in the parts books.
If you're looking for a new wingnut to fill in a gap, 76-81 C3 is 1/4"-20 and readily available aftermarket, bright, or black. I believe the ~88-up TBI V8 cars went M6-1.0
14048874 is probably shorter than the stud for thicker element air cleaners in other applications. 25509829 was used in some of those.
