Why doesn't my speedometer work?
Old Apr 30, 2002 | 05:38 PM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
I made the tbi to tpi swap in my signature, everything went fine except that my speedometer does not work. I have a 700R4 and my VSS has an electronic speedometer. I was told that the pulses are different in a TBI VSS and a TPI VSS. Does anybody know what I need to do? GM shows one VSS for a 1990 camaro? has anybody else had this problem in their swap?
Old May 3, 2002 | 01:04 PM
Ben92RS's Avatar
From: Turkey,NC The true home of Hilljacks everywhere.
I've got the same problem and I am still looking for the answer.
Old May 4, 2002 | 11:59 PM
troutkilla's Avatar
I had the same problem when I done my T56 swap.You need to get a VSS Buffer from Dakota Digital($85) that will allow you to change the ppm.I had a local speedo shop install it for $35,end of problem.......later
Old Apr 1, 2010 | 07:22 AM
tealcamaromanrs's Avatar
Car: 1991 camaro z28 convertible
Engine: 383 tpi
Transmission: t5
Re: Why doesn't my speedometer work?
what if the vehicle already has a buffer box??and i though tpi cars dont have a buffer box and tbi cars do??i know there are a couple of vss sensors between 90-92 so that might be it
Old Apr 1, 2010 | 10:29 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Look here.....
https://www.thirdgen.org/forums/engi...-swap-now.html
Old Apr 1, 2010 | 10:44 AM
Dyno Don's Avatar
Forgot to mention...
Some have a different color to the speedo
Blk is ground
Lt Grn/Blk is to speedo
Red is to cruise
Brn is to ECM
Pnk/Blk is 12v IGN
Old Apr 1, 2010 | 10:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Holy 8 year old post, Batman. . .
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
