LT1 HOT Cam kit in 1989 350 #638??
Old May 11, 2002 | 07:46 AM
SpikeIROC's Avatar
Hey guys, I was wondering if the GM, PN number kit 12480002 (HOT Cam) would fit into my 1989 350 4 bolts casting # 638.
The block originally came roller.
Heads are casting #083 (Hi-Flow heads from 300 hp GM crate engines). They care cast iron and I believe that they have 3/8 studs with 1.5 rocker ratio.
Can I upgrade to 1.6 roller rockers without changing the studs?? I believe they will not clear the valve covers either...
What mods will I have to do to the engine??
Should I simply go with with the good old ZZ4 camshaft and springs? I'm not trying to build a 10 seconds car here, just trying to have plain fun on the street (+ or - 350hp)
Help would be gladly appreciated!!
midge54
Dec 27, 2019 04:14 PM
camaro11j
Sep 19, 2018 08:49 AM
camaro71633
Sep 1, 2015 10:24 AM
kyleb24
Aug 15, 2015 08:24 AM
sreZ28
Aug 14, 2015 07:48 PM
