Mechanical fuel pump on Roller-cam blocks?
Old May 11, 2002 | 11:36 PM
Don Christensen's Avatar
Car: 1989 Formula - Red
Transmission: 700 R4
Axle/Gears: 3.73 Posi
I am seeking a roller cam block that I can put in a carbureted pickup. I believe that the rollers came out in 87, but by then GM was no longer using carbs.
Is this true? Crate motors seem to have both, so what else does? Any help is appreciated - THANKS !!!!!!!!!!
Old May 12, 2002 | 12:42 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
87 blocks had fuel pump provision and all 87-up were rollers. Not sure when they discontinued the fuel pump boss; had to be in the '90's.
A lot of crate motors won't "work with" fuel pumps because of the cam, not the block.
Old May 12, 2002 | 04:52 PM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
Truck engines used roller cams and mechinacial fuel pumps till 95
Old May 12, 2002 | 07:21 PM
89 rs305's Avatar
I had a 91 siverado and it had an electric fuel pump. My brother had an 87 and it came with an electric pump also. I don't know if there was a plate for a mechanical pump or not though.
Old Jun 13, 2002 | 01:25 PM
jmd's Avatar
jmd
On an 87 truck block, there was a blockoff plate. I grabbed the blockoff plate to use on my L69 when I added TPI.
Old Jun 14, 2002 | 11:07 AM
kevinc's Avatar
Car: 1982 Z28
I just got a ZZ4 cam leftover from a FB-385 crate motor (and it's for sale in the Classifieds!!) and it has a fuel pump lobe.
Old Jun 14, 2002 | 03:47 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
My iroc is an 87 and it has a roller motor and a carb (LG4 305)
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
