TPI or LT1 Long Block?
Old May 14, 2002 | 11:12 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
would TPI bolt up to this? I know there are differences betweent eh Lt1 and L98, but I dont know where the differences lay. Im just exploring my options since I need a new engine. I want to keep it below or around $3000 including removla and installation
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1828777664
Old May 15, 2002 | 09:39 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
That LT1 block has the reverse flow heads on it, therefore a TPI intake will not work. I am not sure if the actual block is different. I think it could be.
Old May 15, 2002 | 01:00 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
You could use an LT1 longblock on it, but you're also going to need the accessories and bracket, water pump, and custom PS lines, blockoff the water neck on the intake you have, and some other hose changes.
Old May 15, 2002 | 01:39 PM
Tas's Avatar
Tas
https://www.thirdgen.org/techbb2/sho...threadid=84423
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
bamaboy0323
Aug 15, 2015 07:20 AM
sreZ28
Aug 14, 2015 07:48 PM
Sanjay
Aug 12, 2015 03:41 PM
