Pontiac 400 Tripod
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Pontiac 400 Tripod
Anyone know anything about this engine? I just came across one from my new neighbor, he said he has no more use for it and he would sell it to me with everything including the carbs for 700 bucks. He said it has 10,000 miles on it cause he took it out of a boat. I think it sounds like a sweet deal but what are the specs on these things and would it work with my 700r4?
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
1. it be a direct bolt -on for B-O-P & all GM pattern 200-4R trannies, there may be an adaptor for the 700-r4, but a stock tranny will be killed by this motor.
2. If you don't ****** up this motor, I will find you & smack
you personally
hint: tri power setups, intke w/carbs normally go for $1000 w/o the engine.
Think about it.
you personally
Think about it.
Engine: 3.8
Axle/Gears: Dana 60
*** dang do I feel dumb. The whole weekend I knew that I called Tripower Tripod but couldn't get on the net to correct it cause I just moved into my new place and it has no phone right now.
But anyways, thanks for the info guys.
But anyways, thanks for the info guys. Thread
