383 stroker crank
383 stroker crank
i bought a used 350 tpi engine for cheap from a friend that im having completely stripped down and im probably only going to use the block and the bare heads, i want to get a stroker crank for it but im not sure which would work best and would still be economically feasible. i heard someone say their 383 stroker blew up so they had to make a 388, is this common? and what connecting rods, pistons, etc would you reccommend? thanks
Russ
xxslayahxx@aol.nospam.com
AIM- xxslayahxx
Russ
AIM- xxslayahxx
Transmission: 4L80E/4L80E
I would suggest you get an entire stroker rotating assembly, available through Summit, Jegs, Powerhouse, etc.
383 = 350 block with 3.75" stroke crank, bored .030" over (standard rebuild overbore). 388 is same with .060" overbore, which is typically the max a bore can be safely bored.
383's will last a long time if built with good parts. Fellow racer here has a 7-year old 383 in his '57 Nomad, told us recently he's put over 850 runs on the engine. Adjusted the valves once - he thinks...
Car: Camaro
Engine: 355c.i.
Transmission: th350
enginekits.com has a couple kits for real cheap...i think 500 bucks for a rotating assembly for a 383...gets alittle bit pricier tho if you want forged parts and what not.
what do you guys know about "hardcore racing"? i seen a rotating assembly through them for like 1800 i think... would that be a good idea? or should i get a forged crank from summit and get rods and pistons and bearings from other places/companies? any suggestions about how to get this 383 goin cheaply but effectively would be greatly appreciated.
Russ
Russ
if u wanna keep the price down i saw a add in i think super chevy that was a 377 stroker kit. its the same as a 383 but it has standard bore instead of .30 over. that would at least save u the cost of boring it out. dont know what kinda proformance diff would be between .30 but not sure. i wanna say the kit was like 650? they also had 383 388 kits for the same price. sorry but ill try to find the add here after while
kolby
kolby
Chevykid810
Sep 28, 2015 12:57 PM
Andrew Prakash
Sep 8, 2015 11:48 AM
