305TPI to 350TPI conversion
Old Jun 17, 2002 | 06:04 PM
wolffman007's Avatar
I have an 85 Iroc-Z it has a 305, the motor is getting tired and I have a mid 80's 350 (going to run the #'s) it is a passenger side oil tube. Im trying to verify what parts will need to be swapped out. I am keeping the fuel Injected TPI
I know of the following so far
Injectors for a 350
Computer and/or chip
Knock sensor and/or module (what exactly is this thing ?)
I know the oil pan may fit off the 305 (the 350 is from my 85 S-10 Blazer that is another project conversion, it has a special deep sump oil pump & pan)
will the flex plate from the 305 fit on the 350 & work ? if not what do I need ?
anything else ?
Old Jun 18, 2002 | 09:26 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can probably get along just fine with the 305 injectors and computer/chip, if the cam is reasonably mild. I'd recommend an adjustable fuel pressure regulator, though.
If the 350 is '86-later, then you might need a different flex plate. Other than that, it should bolt in and run.
How well it will run with the '85 TPI system is another question. From what I understand, that wasn't the most sophisticated system. Exhaust, runner length, etc., may also hamper the 350 performance. Porting the base & plenum while it's apart might be a good idea.
Old Jun 18, 2002 | 03:25 PM
does anybody know if the computer has to be replaced or is it just a chip inside that needs it ? & what or wohere would be a good place to get it/them ?
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
