Where to mount LT1 computer ??
Old Jun 28, 2002 | 06:52 PM
STRYKER's Avatar
Subject pretty much says all. Where do you guys have your computer mounted for your LT1's ? Any pictures would be greatly appreciated !!
Old Jun 30, 2002 | 11:56 AM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I mounted mine horizontally above the brake booster. I used two threaded holes in the firewall formerly used for mounting the relays. ( I welded up a custom bracket)It fits under the hood with no problems and is out of the way.
Kory
Old Jun 30, 2002 | 01:18 PM
STRYKER's Avatar
Thank you Kory, anyone else ??
Old Jul 1, 2002 | 12:49 AM
TexasLT1's Avatar
Car: '92 RS
I got longer bolts that hold down the back of the fuel rails, made a plate with some spacers on it, and mounted it horizontally above the back of the engine
Old Jul 1, 2002 | 10:02 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Mine is going to be mounted in the front of the car on the battery tray on the drivers side of the car. I have a Caprice PCM and Harness and that is where the PCM sits on those cars.
Old Jul 2, 2002 | 09:11 AM
mat89RS's Avatar
Mine is where is just above the heather fan.
Old Jul 2, 2002 | 09:13 AM
mat89RS's Avatar
I also can't write
midge54
Jan 29, 2017 07:00 PM
fbirdroller
Sep 2, 2015 10:27 PM
zayne0
Aug 24, 2015 07:22 PM
sreZ28
Aug 14, 2015 07:48 PM
Thirim
Aug 9, 2015 06:19 PM
