1976 350 swap Oil dipstick question
Old Jul 1, 2002 | 02:38 PM
BlakCamZ28's Avatar
I just swapped a 1976 4 bolt main 350 into my 84 camaro. The only problem I have run into with it is that the dipstick on those motors was on the driver side and using the stock hole it won't clear the headers. I was just wondering what you guys have done to remedy this problem?
Old Jul 1, 2002 | 06:18 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I have 1 5/8 full length hedman headers and they worked with both passenger and driverside dipstick blocks. I had to bend the dipstick tube a little to make get it to fit the way I wanted to so you may try that if you haven't already. If that doesn't work you may need to buy a different type of header.
bellez77
Sep 5, 2015 08:39 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
