305 TPI to 355 or more likely 383 Stealth Ram!?
Car: 91 Z28 LS Swapped
Engine: 5.3 Turbo LS
Transmission: T56 Mag
Im planning a swap from a 91 305 TPI to a high-bryid 355 or 383. Anyone with comments on the 355 vs 383? Also Im trying to make sure I have all bases covered with the electronics...please give any additional needs to the following as well as some pointers if you can!
If I have done my home work right, I should only need the following to do this swap?? Help me add to the list if not...
Any kind of help would be great!
New PROM
New 350 knock sensor
Larger Injectors (at least 25lb+?)
Ajustatble FPR?? (sending unit should have plenty of power?)
New PROM
go for the 383 it might cost a little more but like the old saying says there is no replacement for displacement
it will also let u rev higher becasue its gonna be astroker and has to be balanced and thoes stealth rams work better at higher rpm's. for the prom just buy all of the stuff to burn your own it will cost u less in the long run and it will let u tune your car alot better than anyone else could if u know what ur doin. and also u might want to buy a new radiator becasue the engine will be hottor and it will just be better to keep it cooled. hope this helps and good luck!
it will also let u rev higher becasue its gonna be astroker and has to be balanced and thoes stealth rams work better at higher rpm's. for the prom just buy all of the stuff to burn your own it will cost u less in the long run and it will let u tune your car alot better than anyone else could if u know what ur doin. and also u might want to buy a new radiator becasue the engine will be hottor and it will just be better to keep it cooled. hope this helps and good luck! Thread
9192camaro
16
Feb 3, 2019 12:21 AM
Sanjay
Aug 12, 2015 03:41 PM
L98GTA87
Aug 11, 2015 06:55 PM
