305 tpi to 305 carbed
Old Jul 29, 2002 | 12:59 AM
holmes677's Avatar
im in the process of replacing the 305 tpi in my 86 Z, with a carbed 305 HO from a 84 Z, what will i have to do to make this thing work?
Old Jul 29, 2002 | 08:47 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I assume you mean you're replacing the TPI induction system with a carburetor. The answer depends upon whether or not you're using the factory '84 carb system. If so, then you need to change the engine wiring harness and computer, and either reduce the pressure coming from the in-tank fuel pump down to 5-7 psig before it gets to the carb, or remove the in-tank pump and just use a mechanical on the engine. There may be issues with getting the electric to run w/o the TPI computer, but I'm not clear on those details.
Just curious, if you are indeed changing from TPI to computer-controlled carb: Why?
Old Jul 29, 2002 | 09:46 PM
holmes677's Avatar
I'm sorry, i meant switching the entire engine. The block on the tpi engine is cracked. Im replacing it with an entire other engine. How would i turn the pressure down?
Old Jul 30, 2002 | 09:34 AM
ATOMonkey's Avatar
I'd seriously consider putting the stock TPI on your new long block. That's my opinion. Mallory makes a good 3 way regulator. You'll also need a way to measure pressure. Also I would recomend leaving all of the stock TPI wiring on the car. Don't cut anything. This way you can install an aftermarket FI system down the road when you get more cash. It is far superior to Carb in almost every way. All out performance is a wash, but FI drives better, gets better fuel economy, starts and idles better, and actually fits under a stock hood. Hope we could help you there. Oh, you're also going to need the throttle/TV bracket, vacuum hoses, choke cable, and some other misc things I can't think of right now.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
