305 to 350 Swap
305 to 350 Swap
I'm currently down to the final days, just needing to assemble my engine. 355 with Camel-Back heads(2.08/1.70 ports), Speed-Pro .125 dome pistons, .555 lift camshaft,Edelbrock Streetmaster intake, and carbueration is to be decided. Do i need to keep the computer in my car after this swap? Will i need to keep for the 700r/4 tranny? I'd like to pull the computer personally but i'm not sure if i need it for anything...Any help would be grateful. Thanks.
1984 Firebird
305
Carter Carb
Accel high-coil
Accel Spark plugs/Wires
Edelbrock Streetmaster Intake
1984 Firebird
305
Carter Carb
Accel high-coil
Transmission: 4L80E/4L80E
The computer isn't doing anything for you without the original CC carb and distributor, including anything for the transmission (all it did there was lock up the torque converter - without the signals from the carb & distributor, it won't do that anymore).
