quick distributor gear ? wen doing tbi to carb
Old Aug 14, 2002 | 11:37 PM
Makaveli's Avatar
i searched and i couldnt find what i was looking for hehe
do most aftermarket vac advance distributors have a broze gear that can be used with a roller cam? when swapping TBI to carb, and your faced with the whole distributor swap thing.. are distributor choices limited? would like the MSD street probillet ready to run model.. or pertronix flame thrower etc can you use those with a roller cam? if you cant... can you swap the broze gear from the stock one onto the new one?
what distributor would u use if you cant use those with a roller cam?
thanks
Old Aug 15, 2002 | 06:20 AM
ede's Avatar
ede
there is no limit to ignition choices with a SBC, reguardless of induction or fuel delivery system. you don't need a bronze gear with a factory roller, only with a BILLET AFTERMARKET roller cam. aftermarket stock replcement rollers also don't require a bronze gear. i doubt if you find many distributors with a bronze gear, you'll have to buy and install it yourself.
junkcltr
Aug 2, 2019 11:12 PM
pimp2303
Jul 27, 2017 02:03 PM
cstrobel65
Aug 15, 2015 10:19 AM
tero
Aug 6, 2015 06:34 PM
