Casting numbers
Old Aug 19, 2002 | 09:51 AM
kevosiroc's Avatar
Casting numbers
I need to know what casting numbers to look for an a f-body L98 block. I am buying a used longblock from a guy and just want to make sure that he gives me a 350 and not a 305. What else could I use to determine the engines validity??
Help Please
Old Aug 19, 2002 | 09:55 AM
ATOMonkey's Avatar
You could always take the heads off and measure the bores. Or, if you're real brave you can CC the combustion chambers with alcohol. Run the #1 piston up to TDC and start dumping alcohol into the spark hole until it falls out. 305 heads are 58cc and 350 heads are 64 cc I think. The casting number thing is probably the best way to go.
Old Aug 19, 2002 | 12:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
www.mortec.com
Old Aug 19, 2002 | 01:11 PM
kevosiroc's Avatar
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
