ZZ4 help
ZZ4 help
I having problems getting a bracket for my 88 Camaro's A/c compressor. We did a ZZ4 swap, the 355hp version in place of 305tbi and the original bracket does
nt fit. -- any information would be of much use.
Thanks in advance.
Ryan
Thanks in advance.
Ryan
You dont need a new bracket you just need to drill a hole for the old bracket to work. Make a template from the old head and take a bit and mark the depth of the hole in the old head so you dont go to far in the new one.
Originally posted by FallenEmpire
that worked for you? or did your heads come with the correct drill pattern to make it a little easier to swap the A/C compressor mounting bracket
