HP estimate and ET possibility
Old Sep 21, 2015 | 09:21 PM
italiano67's Avatar
Car: 1989 Iroc
Axle/Gears: stock axle 3:27 gears
Here are the particulars of my new rebuild.
350 .60 over
Flat top pistons
L98 aluminum heads(stock rebuild)
ZZ4 cam
Edelbrick hi flo intake
Arizona Speed and Marine runners
Ported stock plenum
Balanced
Underdrive pulleys
AIR and Egr delete
New multitec injectors
New stock Dizzy
Hedman Headers
Hi flo cat
PCM for less chip
3:70 rear gears
Stock transmission with Transgo shift kit and Corvette servo
What flywheel hp do you think it will make what quarter times guestimate in an 89 IROC with fairly sticky tires?
Old Sep 22, 2015 | 08:42 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: HP estimate and ET possibility
Has potential toget low 13's possible high 12's properly setup but needs 2800 stall or there abouts
I'd say mid 13's with a 2.0 60 ft.
Thats a 250 whp combo easily well tuned. Maybe closer to 260 with that cam
LC2 TECH
Oct 13, 2015 11:53 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
mfp189
Sep 27, 2015 09:25 AM
