compatibility of gauges vs 350
Old Aug 24, 2002 | 11:02 AM
rssman80's Avatar
Ok, I have an 89 rs that had a 2.8 in it, I am currently doing a motor swap to a 350 carb setup. My question is, will the oil pressure sending unit, tachometer and temp sensor be compatible with my gauges?? They are the stock v6 gauges. I went out and bought a new sending unit for the 350 and still need to get a temp sensor. Also, i have a stock HEI distributor on it too. Any help would be greatly appreciated.Thanks in advance
Old Aug 24, 2002 | 11:12 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i am not sure so dont quote me on this but i think if they are mechanical the oil and voltsand water should work but i dont think the tranny will if u swap trannies. it will need a new speedo cable. i hope his is right. maybe others will chime in if i am wrong. if they dont work just buy some autometer gauges i knw they are more money but i would trust one of them over the stock gm crap they put in there. i have owned 4 cars in my life tempo s10 elcamino and a camaro and all except the tempo had bad fuel gauges and oil and volts. the only thing thats worth a damn is the speedo but even that was fudged up in the elcamino
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Eric-86sc
Aug 24, 2015 09:01 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
