LT1 cooling question...HELP!!!
Old Sep 4, 2002 | 10:06 PM
sinner's Avatar
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
i am now putting a '95 LT1 in my '92 Z28.
i got a 34,00 mile motor, a set of coated SLP headers, and a painless wiring harness. i am trying real hard to do this right. the last thing i need to know is which set of fans to use. i know i need the 4th gen radiator cause its reversed cooled. i need to know if i can use my stock third gen dual fans or if i need the 4th gen ones. PLEASE HELP!!! its all i need to finish the project!
Old Sep 5, 2002 | 12:32 AM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
Your third gen dual fans will work fine.
Old Sep 6, 2002 | 10:05 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
You can use your stock thirdgen radiator to make things bolt up much easier. You can IM me with questions if you'd like...My SN is Thirdgen Camaro.
About the cooling setup, It's not very difficult to figure out. You can EASILY reuse your existing radiator and fan setup...you just run your lines slightly differently. Here're the pieces you need:
'94 corvette lower radiator hose
'95 Camaro Z28 upper radiator hose
3/8" brass coupling
18" 3/8" ruber cooling line
6' 5/8" heater hose
6' 3/4" heater hose
assorted hose clamps
Two caps for about a 5/8" tube.
Here's how you need to run this using the stock radiator: use the 'vette lower radiator hose to connect the radiator to the gooseneck on the LT1 water pump. Use the Camaro upper radiator hose to connect the radiator to the LT1 water pump. (you may have to grind off a little of your existing radiator shroud, but it's very minor work). Now on the upper radiator hose, there will be a 3/8" rubber line kinda splicing off of it. What you need to do with that is take the brass coupling, put it on, and take the 3/8" extra piece of tubing you bought and connect it to the brass coupling, therefore extending the tube coming off the upper radiator hose. Now route that 3/8" hose under the throttle body so it pokes out past the TB on the passenger side. There you will snake it around and connect it straight to a metal coolant line that runs along the bolts on the passenger side of the intake all the way to the back of the heads. That will eliminate the need for you using the TB to pass coolant, and giving you the cheap TB bypass mod. Now to route the lines to the heater core. Take 6' of 3/4" coolant line and run it from the upper port on the water pump all the way to the 3/4" opening on the heater core. Since you have 6' to play with, you can route it pretty much anyway the hell you want (they sell pre cut 6' rolls of this stuff for $3.99 at the auto parts stores). Now take the 5/8" heater hose and run it from the lower port on the water pump (BTW, both the ports for the heater core on the water ppump are on the passenger side) and run it all the way to the 5/8" port on the heater core. Now you have pretty much all the lines run. This is now an optional/conditional point of the coolant routing. Are you going to be using the stock LT1 oil cooler? If you are, you will not have to buy the 2 caps for mentioned in the parts list, but you will have to buy 6 more feet of 5/8" cooling tubing. There'll be one port one the drivers side of the waterpump for the oil cooler. You run a hose from that port to the oil cooler, and a hose from the oil cooler back to the opening in your radiator (which was originally used as a return from the heater core in a stock setup). If you do not plan to use the oil cooler, just block the ports on the radiator and waterpump. You'll be all set. That's the whole cooling setup. Not too hard if you understand it, and I think I explained it fairly well.
If there are any more questions about wiring/routing or what not, don't hesitate to give me an IM or e-mail.
Old Sep 7, 2002 | 10:35 PM
sinner's Avatar
wow, your awesome. that answers the questinos i had, in great detail. you bet ill e mail you with questions. thanks so much.
:hail: :hail: :hail: :hail:
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
