getting out of the TBI game
Old Sep 7, 2002 | 03:33 PM
jmp1999's Avatar
AT the risk of making a lot of people unhappy. What all Do I have to do to convert from TBI to carb. MY Real concerns are with the ignition. I know that I can pull my harness and tbi and intake and computer relativley easily. But what do I have to do about ignition. (tourque converter already controlled by vacuum, so no prob there.
Thanx 4 yor time,
Joel
Old Sep 7, 2002 | 07:00 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
why the hell do you ask on the TBI board about going to a carb? ask on the carb board! with that being said read the sticky on the carb board, there is a tech article on this very site. now to help you out, you will need a non computer controlled distributor. i used an accel HEI one, it cost 100 bux plus my friend gave me a accel coil.
Old Sep 7, 2002 | 08:15 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Heh-heh-'eh. . . Run the carb and keep the ECM for a timing computer. I've run several vehicles that way already. It is amazing what an ECM can do for timing control.
RBob.
Old Sep 7, 2002 | 08:19 PM
but then you still have the stock timing tables
Old Sep 8, 2002 | 09:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Uh, burn a new EPROM?
RBob.
Old Sep 8, 2002 | 10:52 AM
RBob.
Uh, get a new HEI distributor. then you dont have to buy a bunch of prom ****
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
