LT1 harness question
did you get the harness for a 93-94 or 95 up?
the tranny connectors dont need to be used, however if not used will cause a problem if you have to get smog tests since it will not control the engine based on speed, since the harness is designed for a 4L60 or 80E tranny. when you get the harness every thing will be explained in the install manual (they explain everything alot better than I thought that they would have) it will be illistrated with pics and also the normal instructions and every wire has a little white label on it so the really dumb people who cant figure out that if it doesnt plug in, it doesnt go there!
(not calling you dumb)
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
i got the one for a '95. i was reading the product info and it was 4 a 4L60E and 4L80E. i am removing all emissions equipment so that wont mater. still think it will work?
