attn Firebird Stealth Ram Swappers!
Old Sep 23, 2002 | 04:12 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Can someone please post a picture of the underside of your stock hood where you modified it for clearance? I'd like to get an idea of how much chopping has to be done or else I'll just buy a ram air. Mucho Thanks!
(PS my hood is formula style, but it would be helpful if we had pictures of all factory bird hoods)
Old Sep 23, 2002 | 07:09 PM
e-man's Avatar
Car: 89 formula
Engine: 383
I dont have a pic but if you take the hood liner off you will see the brace running across the middle just cut it a inch off the sides of the TPI.
Old Sep 27, 2002 | 02:35 PM
JMatlock88's Avatar
Car: 1991 Formula
Did you cut it with an air cutoff tool? How'd you see where it was hittin'?
Old Sep 27, 2002 | 07:46 PM
e-man's Avatar
Car: 89 formula
Engine: 383
The T-body is what hits I took plastic and taped it to the plenum and rubber intake then put grease over it.closed the hood as low as it would go the grease marks the under side of the hood.I dont think you dont want to cut the way I did. I used sheet metal shears and its not the cleanest cuts.If I were to do it again I would put a sheet or blanket over the engine and use a grinder with a cut off wheel or a dremel tool.I cut the whole brace out of the center.
Old Oct 1, 2002 | 04:59 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
My stealth ram fit nicely with a few well placed whacks with a "ford" tool (ie, 5lb sledge). This is with a flat base model hood. I used the same technique with the grease to see where it would contact. I now have at least 1/4" of clearance around the throttle body and plenum
Old Oct 1, 2002 | 06:15 PM
JMatlock88's Avatar
Car: 1991 Formula
slickROCK, does that refer to iroc or are you still talking firebird? Thanks
Old Oct 3, 2002 | 10:03 PM
Car: 82 Trans am
Matlock, thats referring to a trans am actually, but has the stock firebird hood from a previous owner (accident??)
Old Jul 6, 2003 | 09:55 PM
88blackbird's Avatar
Car: 88 Trans Am GTA
Will a ram air II hood clear it??
Old Jul 6, 2003 | 10:02 PM
JMatlock88's Avatar
Car: 1991 Formula
ra 1 and 2 will clear the hsr
Old Jul 6, 2003 | 10:03 PM
JMatlock88's Avatar
Car: 1991 Formula
search my posts for where and how to cut the stock hood along with other necessary mods.
Old Jul 6, 2003 | 10:44 PM
Thanks JMatlock!!!
9192camaro
16
Feb 3, 2019 12:21 AM
Mutillator
Sep 17, 2015 04:38 PM
mddaniel
Sep 8, 2015 05:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
