Can someone run some numbers for me please??
Old Sep 23, 2002 | 07:06 PM
GTA400SBC's Avatar
these are the numbers i found on the back drivers side by the bell housing.Can you tell me what it is and what year it is and what kind of vehicle it came out of.the numbers read as follows
3951509
if there are any more numbers i need just let me know and i'll get them for you. Thanks alot
Old Sep 23, 2002 | 09:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It came out of a Chevrolet.
509 is the most common 2-bolt 400 casting. It ran from at least 72 to whenever they quit making them. Mine is a 73 model of that casting. There is a series of numbers near the casting #, that might look something like 14E3; this example would indicate the 14th day of the e-th (5th, May) month in a year ending in 4, probably 74 if it's a 400; a block with that number would have most likely been installed in an early 75 production vehicle.
The block does not care what kind of sheet metal the factory wrapped it in, or really, when it was wrapped, beyond just curiosity. If it's just the block, the casting # tells you all you really need to know. If you have the heads that came on it (probably 882 casting), please have them destroyed immediately, in order to protect the world from castings that will limit a 400-CID engine to 180 HP.
What info are you looking for?
Old Sep 25, 2002 | 03:36 PM
GTA400SBC's Avatar
where are the casting #'s on the heads so i can see if they have the #882
Old Sep 25, 2002 | 04:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Under the valve covers, between some of the rocker studs.
624 is another one that some came with, that screams for destruction.
Old Sep 26, 2002 | 05:59 PM
GTA400SBC's Avatar
the numbers i found on the heads are 458642 then in the middle of the head ther is are the letters GM then under them are the numbers 62. so what heads do i have????
Old Sep 26, 2002 | 08:02 PM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
Are you sure it's not 468462? Go to www.mortec.com and they have a listing of head casting #'s.
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Steve78LT
Feb 24, 2016 12:15 AM
ezobens
Aug 19, 2015 10:29 PM
armybyrd
Aug 10, 2015 09:23 PM
