balance, blueprint?
Old Oct 16, 2002 | 06:49 PM
flippinTHEbird's Avatar
balance, blueprint?
What exactly is done when a block is balanced and blueprinted?
Old Oct 16, 2002 | 08:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Balancing is just that. The rotating assembly is disassembled and everything is weighed. All the con rods are brought down to the weight of the lightest rod. The same thing is done to the pistons. The combined weight of the con rod and piston assembly is then transfered to the crankshaft, and flexplate with balancer if the engine is externally balanced, The crankshaft is then balanced to match the new adjusted weights by added or removing weight. Whenever you change pistons or con rods, the engine should be balanced.
Blueprinting is a little different and not always done. What blueprinting does is puts all the engine tolerances to an exact number. If they say that crankshaft endplay can be within .001-.005, you adjust it to .003 so it's right in the center of the tolerance. The gains reached from blueprinting don't justify the expense of doing it. Just as long as everything is within the tolerances, it will work just fine.
Chevykid810
Sep 28, 2015 12:57 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
