quick question about 305 and 350
Old Oct 20, 2002 | 07:23 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
will a 350 head from 1986 fit on a 305 block from 1986?
Old Oct 20, 2002 | 07:50 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
yes but
Yes it will question is will it give you the results you want ?
305s want heads with 55-58cc's and 350s have heads with 68-76cc's. If you put 350 heads on a 305 you may drop compression below acceptable values. Find out how many cc's the 350 heads are first.
RP.
Old Oct 21, 2002 | 07:15 AM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
I belive its of more benifit to put 305 heads on a 350? someone correct me ifim wrong
Old Oct 21, 2002 | 03:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
An '86 350 head should be 64cc. I'm not completely sure what they did with truck or full-size heads that year, though.
One benefit would be a larger intake valve - s/b 1.94" vs. 1.84" for the 305 heads. You should see improved flow, but there are "bad" 350 heads out there, too. It would be best to shave them down to 58cc chambers, which would require removing ~.04". If you do that, have the intake manifold shaved by the machine shop to match - prevents leaks.
305 heads on a 350 increase compression due to the smaller chambers. To really improve performance, though, they should be ported and the above-mentioned 1.94" intake valves installed.
Old Oct 21, 2002 | 07:02 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
only thing i know is both the 305 block is stock and so are the 350 heads the heads came from a Vette and the 305 is from a Z28 Camaro
Old Oct 21, 2002 | 09:46 PM
Guest
Guest
Posts: n/a
I hear that the 350 vette heads (the cast iron ones) are 76cc. If so, you really dont want to use those on a 305. The aluminum ones you wont lose any compression, but they arent as good as the later aluminum vette heads.
As for bolting up, you can bolt up any SBC head to the block, only differences I can think of right now are the accessory bolt holes (or lack of) and intake bolt angles on the center 4 bolts. That and a 305 has a relatively small bore, which does not work well with large chambers and large valves. Could have issues with the valves hitting the block. All depends on what the heads are though as to if they will work or not.
Old Oct 22, 2002 | 06:25 PM
five7kid's Avatar
If the heads are cast iron and came from an '86 Vette, they are 64cc.
If the heads are aluminum and came from an '86 Vette, they are 58cc. But, they're smaller to increase compression in order to compensate for the heat loss through the aluminum - on a 350.
So, either one should be shaved to maintain proper compression and power on a 305.
Jake_92RS
Jan 28, 2020 10:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
