385 Fast Burn swap
Old Oct 21, 2002 | 04:19 PM
88ROC1LE's Avatar
385 Fast Burn swap
I am thinking of installing a 385 Fastburn crate motor in my 88 IROC. I have read the tech article on switching the TPI to carb, but is that a good guide for installing a crate carb motor? Also will it fit under my stock hood?
P.S. I did a search, but didn't come across to much information
Old Oct 22, 2002 | 12:46 PM
88ROC1LE's Avatar
Old Oct 22, 2002 | 01:44 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
The guide for TPI to carb is pretty good. In the guide they don't like the Mallory fuel pressure regualtor but that is what I use and it seems to work fine for me. Is the intake on the Fastburn 385 a single plane or dual plane. If it is a dual you should be able to clear your hood with a drop down air filter setup. A single plane intake makes it pretty much impossible to clear the hood.
Old Oct 22, 2002 | 11:14 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
The intake is a dual plane. I am installing one now. Only i stuck with the TPI and am using a miniram with hot cam. It is the same as a ZZ4 only with the fastburn heads.
Old Oct 23, 2002 | 01:30 PM
88ROC1LE's Avatar
Yes, it is the dual plane. I may go ahead and change the hood to cowl. Thanks for the responses!
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Fast355
Dec 2, 2016 06:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
E Rod
Aug 28, 2015 05:17 AM
Exxon Limited
Aug 9, 2015 08:13 PM
