Opinion on this 350 ?!?!
Subscribe
Oct 22, 2002 | 08:17 PM
I am looking at a new 350 for my 87 trans 5.0L. 305. Money is limited, so I am thinking of buying this basic 350, and building off it as I save up.
Here are the specs...
265 HP
357 ft/lbs
NEW 5.7 LITER/350 CID ENGINE FITS LIGHT DUTY VEHICLES 1971-1985
ENGINE FEATURES:
100% New engine, 350 CID, 4-bolt main, V-8, 2-piece rear main seal, nodular iron crank, forged rods, 8.5:1 cast pistons, hydraulic camshaft, 1.94" intake valve, 1.50" exhaust valve, oil pump, oil pan, valve covers, RH and LH dip stick.
* 3 YEAR or 50,000 mile warranty in GM approved vehicles. Limited cam warranty on 265 HP engine.
$$1725
WHAT DO YOU THINK???
GO FOR IT???
Reply 0
Oct 23, 2002 | 07:32 AM
why not just buy a short block ... chances are you'll end up swaping the heads anyways .. *shrug*
Reply 0
Oct 23, 2002 | 08:23 AM
not bad to start with, but your not gonna get the warenty with it. you have a 87, and that engine is made for 71-85 GM approved cars....your car is just a tad to young!...well if i were you, id look around more. go to some machine shops, look in the classified ads, go to www.chitownracing.com and look around in there classified ads. i got my newly built, bored over, forged piston, mild cam, head worked 350 4 bolt main for 800 bucks!!...but i also know people that know people. dont rush into it, shop around. hell you can go to the junk yard and get a good 350 4 bolt main from a truck($400)...take it to the machine shop have them clean it up, make sure its in good shape, then talk to the machine shop guy your budget and see what he can make you. im sure hes got some heads laying around he will give you cheap...or you can just get a decent 3 angle valve job, with all new seals, valves, and seats for around 500 bucks. you have alot of options.
Reply 0
Oct 23, 2002 | 03:31 PM
It may be slow, but you can always BRAG "I got a 350 in it". Look
around, better engines are available.
Reply 0
Oct 23, 2002 | 08:16 PM
what I was thinking was to buy this and then later turn it into a 383. I know that I would be replacing the crank and such, and that the rear main seal along with the pistons kinda suck, but those would be mods to replace as I save $.
Reply 0
Oct 23, 2002 | 08:28 PM
STILL OVER PRICED!! My opinion.
Reply 0
Oct 23, 2002 | 08:42 PM
yeah it is.
Reply 0
Subscribe
