1985 305 to 1994 LT1 350 questions
Old Oct 22, 2002 | 10:29 PM
pepperdad's Avatar
i have a 1985 camaro iroc-z. it's 305 TPI with an automatic 700r4 trans. i want to know if i can swap my engine for a 1994 350 LT1. will i have enough room in my engine bay to fit the new engine? and what will i need to modify/upgrade in order to accomodate the new engine? how big of a job am i getting myself into if i make this decision? thanks
Old Oct 23, 2002 | 11:46 AM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
Here is a link for you to a post that I have started all about lt1 swaps. Also you can use the search button to find out some of your info. I also have a 85z that I am hoping to drop an lt1 in soon. Here is the link good luck and stay in touch. https://www.thirdgen.org/techbb2/sho...hreadid=139614
Old Oct 23, 2002 | 11:51 AM
85maroz28's Avatar
Also to answer your question yes it is possible to do the swap. It will bolt right up if you get rid of your air cond. If not you are getting yourself into even a bigger problem. You are getting yourself into a big project but if you have the knowledge, time, money and patients it does not seem like that hard of a thing. Read through all the links that I put on my post and you will get a better out look on things!!
Old Oct 23, 2002 | 07:39 PM
pepperdad's Avatar
thanks 85
appreciate the links and help.
Old Oct 25, 2002 | 12:38 AM
Cra-Z-Canuck's Avatar
Car: 88 IROC Convertible
Engine: 355 (Finally!)
Transmission: Auto :(
What about l98?
Is the swap to an l98 easier? Can I use the same TPI, electronics, etc. that are on the 305tpi I have now?
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
