305 TPI TO 350 CARBED help!
Old Oct 31, 2002 | 09:20 PM
THELEGENDOFABE's Avatar
got the motors swapped now just curious bout the computer and all the other wires..now hei so tossed the other distributer.. what psi regulator should i use and does the fuel pump have a sensor to turn it on..or should it start as soon as i turn the key a little... im basically confused bout the wires and computer tho..so any input that would make this easier would help..thanks
Old Nov 1, 2002 | 04:15 AM
Joshua Leslie's Avatar
which wires are you confused about?
The fuel pump might work with no problems.
some people dont have problems, I did.
mine woudnt pump, it would prime for 2 seconds, fill the carb. with gas, the car would run for 20 second, then die. it took me a couple days to figure out what was wrong...very fustrating.
What I did was run an on/off toggle switch to the fuel pump. the pump eventually burned out, I dont know if it was cuz it had 156K on it, cuz the regulator, or cuz it was always running of direct battery voltage, so i got a Holley external now.
The carb. should say what PSI regulator you need. Most carbs run about 6psi.
The only wires I connected back up were the hot for the dist. and the tack, the alternator wires, and the starter.
Old Nov 1, 2002 | 08:32 AM
85350TX's Avatar
Just curious what did you do with the TPI set up?
Old Nov 2, 2002 | 03:19 AM
well, I had a TBI setup, but the swap procedue is basically the same.
If you want it, check the nearest landfill by Detroit.
Old Nov 5, 2002 | 01:27 PM
Little Red RS's Avatar
hey since i've gotta 92 and all that computer control crap.. is the swap possible.. i wanted to save up and get a 450 hp crate engine.. it's carb'd so i've been thinking if it was worth it.. it would more than triple my horsepower straight outta the box..
any input would be helpful
Old Nov 6, 2002 | 12:05 AM
sure man, it would work
however,with that much power, you will need to have a performance rebuild done on your tranny, and get subframe connector.
You will also need a posi unit and gears, the motor I put in my car is only about 300hp, and it cant hook up to save my life.
I would also say you would need a hi-po radiator with that kinda power. Power=heat, the stock radiator for TBI cars is only setup to handle 180hp or somewhere around that. I have problems with my car running hot.
also, figure on spending at least 500 dollars extra on the new engine, cuz you will run into unforseen problems, especially if this will be your first swap.
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
