Tpi No Inj Pulse
Old Nov 10, 2002 | 10:36 AM
BADBOWTIESS's Avatar
Tpi No Inj Pulse
I HAVE A 89 GTA 350 TPI I AM NO GETTING NO INJ PULSE THE COLD START INJ WORKS BUT NOT THE REST ENGINE AND HARNESS IS OUT OF 87 IROC ANY IDEAS
Old Nov 10, 2002 | 06:13 PM
kevinc's Avatar
Car: 1982 Z28
If you're running the '89 chip, it's looking for a VATS (vehicle anti-theft system) signal it won't get w/ the '87 harness. That will cause the injectors not to fire.
Old Nov 10, 2002 | 08:44 PM
im using 87 chip and harness
Old Nov 11, 2002 | 06:24 PM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
Have you ever had the car runing?If so check the grounds on the back of the heads I had this problem and the ground was lose..Hope it helps..
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
justin57
Aug 20, 2015 07:05 PM
Sanjay
Aug 12, 2015 03:41 PM
