305 swap in
305 swap in
I have a 84 Camaro it came with 2.8 V6 It now has a 3.8 V6 in it. It still has the 5 speed transmission that came in it, Now for my question I can get a 305 from a 90 camaro for free, what do I need to change to put it in? Will I need a new transmission if so which one should I get, also will I need a new rear end and if so which one? This will be my 1st engine swap is there anything else I should know before I do this? Also my budget is very tight how much do you think everything will cost? Thanks for any help.
Transmission: 4L80E/4L80E
This isn't an easy job. Most everything that attaches to or feeds the engine, including the transmission, needs to be changed. The best way to do this is with a complete factory V8 donor car. Getting the engine for free is nothing - that's not the hard or expensive part.
Unless this car has some particular sentimental value, don't do it. That fact that someone put a 3.8 V6 in it is proof that too much effort has already been put into it.
Of course, putting a turbo 3.8 into it now, since it already has a Buick V6 in it - that's a different story...
